Hi
After update 2009.2 - 2010.2, the DockManager component doesn't work like before.
I have a MDIForm and in the ChildrenForm I have two panels configured like "DockArea Location: Dockedtop" and "Child Pane Style: VerticalSplit".
And other panel with the property "Dock: fill". The property WindowsState in the two forms is configured Maximed.
In the designer, the splitter is in the center of the two panels. In the run-time, in the load of form, the splitter don't is in the center of screen, because of this the left panel width is smaller.
The splitter move correctly after I restore or resize the form.
In the version 2009.2 this not happens, I already tested this. In the run-time, in the load of form, the splitter move for the center of screen, and the two width panel's is equal.
Is there any setting to be made, or is this a bug in component?
Patrícia
Hello Patriciarosa,
This issue has been already fixed in the latest versions of NetAdvantage 2011 vol1 and up. To download the latest service release, please log in to ‘My IG’ and select ‘My Keys & Downloads’. Select the appropriate tab for this product, then the license key. The available service releases should now be listed on the page.
Please let me know if I can provide any further assistance.
I have created the following case for you: CAS-81301-ZRCNCV
I will update you through the case with further details.
If you have any other questions please feel free to ask me here, or through your case.
Several processes are executed before the opening of the forms.
I need a prediction for the correction of this error, it always worked and stopped working in 10.2.
I will be waiting for a solution.
Thank you
Hello Patricia,
I have tested the behavior with the later versions and the it is still the same as in 10.3. I have tried the way around this behavior and it works evertytime for me.
Is there any specific steps that I would have to perform prior running the application in order to reproduce the incorrect behavior when you are using Me.Refresh() ?
Thank you for your cooperation.
I tried this solution and this doesn't working in all tries.
This bug is already fixed in the new version?
I am using the version 10.3.
Thank's
