Is there a way I can specify or draw a custom size symbol - size varies from say 1 to 10?
When I look at the posts, it looks like the SymbolIconSize is restricted to a predefined set of sizes - Large, Medium, Small etc..
Thanks Max.
Not sure why you're getting points in the negative space. Could be due to zooming or a custom range, but I don't think there'll be problems if you get the data from the chart layer, like you did.
Max,
Couple of points here.
1. From dataPoint.point I get the screen coordinates. While most values were +ve, I got some weird long -ve values (eg : -276253) and they still belonged to the PolarLayer. These values can not be mapped to the polar chart coordinates.
2. I can get the x, y and any other column value from the datasource I specified by :
int
rowid = dataPoint.Row;
double dipval = dataPoint.Layer.ChartData.GetValue(rowid, 0);
double azimval = dataPoint.Layer.ChartData.GetValue(rowid, 1);
double propertyval = dataPoint.Layer.ChartData.GetValue(rowid, 2);
and it works great.
Now the question is, will there be a situation when the abovve statements can go wrong.
3. Thanks for helping me with the symbol stroke - that worked
4. Colors, works with simple rgb values, but I may have to go for more complex models. I will have to come back with more questions .
using dataPoint.point already gives you the chart coordinates. If you want to map those coordinates on x or y axis, use axis mapping functions:IAdvanceAxis xAxis = (IAdvanceAxis)e.Grid["X"];xAxis.Map(dataPoint.point.X);
For symbol outline use PE.Stroke.
Here's a code snippet that sets a range of colors:IAdvanceAxis xAxis = (IAdvanceAxis)e.Grid["X"];IAdvanceAxis yAxis = (IAdvanceAxis)e.Grid["Y"];
Color[] colors = { Color.Red, Color.Blue, Color.Green, Color.Yellow, Color.Violet, Color.Brown };foreach (Primitive primitive in e.SceneGraph){ PointSet pointSet = primitive as PointSet;
if (pointSet == null) { continue; } else { int iconsize = 3; for (int k = 0; k < pointSet.points.Length; k++) { DataPoint dataPoint = pointSet.points[k]; Symbol symbol = new Symbol(dataPoint.point, SymbolIcon.Diamond, (SymbolIconSize)iconsize); Color clr = colors[k % colors.Length]; symbol.PE.Fill = clr; symbol.PE.Stroke = clr; e.SceneGraph.Add(symbol); iconsize = iconsize + 2; if (iconsize > 20) iconsize = 3; } break; }}
Not so clean, still this code worked with some issues:
1. How do I get the x,y coord of the chart from the datapoint.point? The idea is to increase the size of points from center to the edge by 1 point, though in my sample code, I am just specifying some random size to see wheher it works.
2. How to give the Symbol outline the same color as fill. Right now, the border/outline of the symbol
is dark (is it black?)
3. Color remained the same for all points. I would like to give a range of colors.
-----------------------------here is my sample code from FillSceneGraph event----------------------------------
if (pointSet == null) { continue; } else { int iconsize = 3; for (int k = 0; k < pointSet.points.Length; k++) { DataPoint dataPoint = pointSet.points[k]; Symbol symbol = new Symbol(dataPoint.point, SymbolIcon.Diamond, (SymbolIconSize)iconsize); Color clr = Color.FromArgb(100,(225+iconsize),(130+iconsize*3),(76+iconsize*5)); symbol.PE.Fill = clr; e.SceneGraph.Add(symbol); iconsize = iconsize +2; if (iconsize > 20) iconsize = 3; } break; }}
