855
When to Resize With Visible Columns Option
Hi.  I'm using the WinGrid version 10.2 and have a question about column resizing.
When I load a grid with data, and call:
column.PerformAutoResize(PerformAutoSizeType.VisibleRows);
The columns are sized based on the column header data, not the data in the rows.  The columns must resized manually.  If I used the AllRows option, the columns resize.
Is there a "trick" to using the .VisibleRows option?  Should it only be used during certain grid events?
