125
Inconsistent UltraComboEditor.Value behavior
I'm a bit confused right now. It's taken a while to narrow down my problem, and it doesn't make sense. I'm binding a list of simple objects to an UltraComboEditor. There's nothing particularly special about the items, or the editor itself. I have manually set the DisplayMember and ValueMember properties, and bound the list. Depending on whilch machine I run on, I get inconsistent behavior from the control. On my dev box (Win7 64 bit, VS2010) I get the proper response back for the Value property of the control. That is, I get the Id property back from the item, since that is what I set as the ValueMember property of the control. On my neighbor's identical machine, he gets back a string which we've determined corresponds to the first alphabetical property of the bound object. This is the same code. I mean exactly the same code. If I build it on his machine, the control returns one thing. If I build it on my machine I get something else.
I thought at first that the presence of a previous version of the controls (2009.1) on his machine might have been the problem, but I have it on my machine, too. I found references to the 2009.1 versions of the controls in the .licx file, so I removed them, and the problem remains.
I am, quite frankly, at a loss. I "Get Latest" to both machines (using TFS), and build... different behavior. Any help/clue would be appreciated.
