70
Can't enable multiline UltraTextEditor
  I have a problem with an UltraTextEditor, but I can't figure out what the problem is.. I start with it disabled, and the when the user click Update, all the controls on the form get enabled, including the UltraTextEditor. The problem is that this mechanism works fine if the Editor is not set up as multiline. When I try set up Multiline = true, the editor becomes disabled no matter what I do.
    It's kinda like this:
editor.Enabled = false;
editor.multiline = true;
Then when I hit Update, I change the properties like this:
if(editor.Multiline)
editor.ReadOnly = not editor.Enabled;
  What could be wrong? Thanks
