Hola tengo un ultrawingrid agrupado en un band por una columan la cual me muestra correctamente,pero quisiera ordenarlo pero no ascendente y descendentemen alfabetico, sino por la cantidad de filas por item agrupado...
alguien sabe como hacerlo?
I do not speak spanish but I ran your text through google translate and it looks like you want to change the order of the group by column display based upon the # of child rows for that group by row. Correct?
<http://help.infragistics.com/NetAdvantage/WinForms/2010.3/CLR2.0/?page=Infragistics2.Win.UltraWinGrid.v10.3~Infragistics.Win.UltraWinGrid.UltraGridColumn~GroupByComparer.html>.
This help link is the GroupByComparer property of an UltraGridColumn and it shows how to do what I think you want to do (if the translation was correct...)
For example using the Northwind Orders table as the source for the grid you could do the following:
private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e) { UltraGridColumn countryCol = this.ultraGrid1.DisplayLayout.Bands[0].Columns["ShipCountry"]; if (countryCol != null) countryCol.GroupByComparer = new MyGroupBySortComparer(); }
class MyGroupBySortComparer : IComparer { public int Compare(object objx, object objy) { UltraGridGroupByRow x = (UltraGridGroupByRow)objx; UltraGridGroupByRow y = (UltraGridGroupByRow)objy;
return x.Rows.Count.CompareTo(y.Rows.Count); } }
You will probably have to run this text through a google translate as well to read what I've written. Let me know if this is the behavior you were trying to achieve.
