245
Column does not resize
We are using Infragistics Win 10.2. Sometimes when we try to resize a column by dragging the border, it does not resize. This happens intermittently and is only when there is a lot of data loaded in the grid and high resource utilization.  A restart usually fixes this issue. Is this a known issue? Is there something we can do to fix this?
  • 469350
    I'm not aware of any issues like this. Can you reproduce the issue consistently?
    What exactly happens when the column doesn't resize? Do you see the line indicating that the column resize is in progress as you drag the mouse? Or does the column simply not allow you to even begin the drag?
