Hi guys we moved our existing application to the Microsoft CAB architecture as we can't move to WPF right now ...
I have found very useful the integration available through the Infragistics SDK which provides everything to integrate Infragistics in CAB.
The only lack is in the documentation, do you have any API or anything like that about how to use it? I mean, it should reflect CAB syntax but I still don't know how to use the commands and other things.
Thank you.
Thanks a lot!
You can check out the following KB Articles on the NetAdvantage CAB Extensibility Kit:
http://devcenter.infragistics.com/Support/KnowledgeBaseResults.aspx?type=Full&query=CAB+and+Extensibility&articletypes=0&age=0&sort=LastModifiedDate&samplesonly=0
