I have the winganttview control and have our sql database databound to the project and task properties. All has been working well until I change the FontData property. If I set the Cell to be Bold, Italic, change color etc, when I go to save the values the AllProperties field in the database is now Null. That is causing all of the other values stored in that same field to be lost.
What is causing the AllProperties field to be cleared when changing the FontData property?
This issue has been resolved in the latest Service Release.
Thanks for the response. I can live without that until fixed. Just wanted to make sure I wasn't doing something wrong.
manleyd said:What is causing the AllProperties field to be cleared when changing the FontData property?
