1440
Nested UltraDropDownButton has sporatic behavior
I have a form that contains a UltraDropDownButton that displays a user control that also has a UltraDropDownButton.  The sporatic behavior that I've been noticing is when you click on the nested UltraDropDownButton,  the parent dropdown will close exposing the nested dropdown as if was a detached window in the upper left area of the form.  The controls on the detached  dropdown function properly but the data is not persisted.  When I click on the parent UltraDropDownButton, the problem is corrected.
To date, I haven't noticed a pattern causing this behavior.  What do you suggest I do to correct this problem?  The app is using the controls from NetAdvantage Winform v10.2.
Thank you
Clay Seifert
  • 71886
    Hello Clay,
    I was not able to reproduce your scenario, so I attached a sample for you. The UltraDropDownButtons seems to work fine in this case. Please review the application and feel free to let me know if I misunderstood you or if you need any additional assistance.
    NestedDropDownButtons.zip
