785
UltraDateTimeEditor - value shown as 'd/10/2010' when regional settings are set to Australia
We are making use of the UltraDateTimeEditor in our application and when the regional settings are set to English(Australia), the day portion of the date displays as a 'd' instead of the value.
Has anyone seen this before?
We are using version 6.3.20063.53.
Aside from upgrading to a more recent version of Infragistics, is there a property or setting that should be set to fix this?
Thanks.
Annie D.
  • 785
    Verified Answer
    This will happen if you set an improper input mask like 'd/mm/yyyy'.
    Once I changed it to 'dd/mm/yyyy', the value was display correctly.
    Annie
