I have a Grid bound to a datatable.
It is not bound to the database via a Adapter or anything so I have to handle the DB update myself.
In the AfterCellUpdate event I populate a DataView with my DataTable and check for the RowStateFilter
However it never finds the row that I just modified.
In the CellEventArgs of AfterCellUpdateit it does show that e.Cell.DataChanged is true and the value in the DataRow is changed, its just not marked as modified so I can't do my DB update
How can I make this change to modified?
I`m not sure what exactly is your scenario, but maybe you need to set a property UpdateMode of your UltraGrid. For example:ultraGrid1.UpdateMode = Infragistics.Win.UltraWinGrid.UpdateMode.OnCellChangeOrLostFocus.
You can get the modified rows by using:- DataTable dt = new DataTable();- dt.GetChanges(DataRowState.Modified);or -DataTable dt = new DataTable();-DataView dv = new DataView(dt);-dv.RowStateFilter = DataViewRowState.ModifiedOriginal If you would like to accept the changes that are pending in your DataTable you could call AcceptChanges() method.Please if you have any questions, do not hesitate to ask me
