Hello
I have bound the grid to a dataset. The grid has 2 bands. At the begining, the first band had 4 columns, but I had to add 4 more. Although all the columns has the property Hidden = False, some of the new columns do not appear at runtime. Strange enough, those columns do not appear in the Column Arrangement facility (when selecting the "Use Row Layout Option"). The missing columns have a width greater that 20.
What could be wrong?
Thanks a lot.
If the columns weren't updated in the designer, it is possible that the NewColumnLoadStyle is set to Hidden and that would prevent you from seeing the columns at run time. You may also want to check the keys to your columns and verify that they are all correct.
If this doesn't address the issue, then it would be best to have a sample that reproduces the issue. Specifically we would need the definition for the DataSet and the designer generated code for the form or user control that the grid is on.
Let me know if you have any questions with this matter.
Hi EmoscosoCam,
I am currently in the process of reproducing this anomaly, I will update this thread once a reproducible sample has been constructed at which point I may be able to offer an appropriate solution.
Please let me know if you have any questions at all regarding this issue. Sincerely,Chris KDeveloper Support EngineerInfragistics, Inc.www.infragistics.com/support
