I'm having trouble with Infragistics 2008.3 UltraExplorerBar and also with toolbar Ribbon control under Visual Studio 2010.
Whenever I try to load an image from Resources into ExplorerBar (or Ribbon) item, I get the following error message:
Code generation for property 'Image' failed
Doesn't Infragistics 2008.3 (WinForms) work with VS2010?
From the Supported Environments page:
Visual Studio 2010 NetAdvantage for .NET 2010 Volume 1 Service Releases or later.
You can find it here: http://ko.infragistics.com/support/supported-environments.aspx#SupportedEnvironments.
8.3 does work with VS 2008 but is not listed as supported for VS 2010.
