Good Morning everyone,
i have a question regarding the Ultrasplitters. Is it possible to successfully use 2 splitters in one panel?
I want to achive a two time foldable row with 3 groupboxes.
Is this possible to do such a thing with the combination ob ultrasplitters and panels, or how else can i create the desired effect, by using NetAdvantage 10.2 Win Tools?
Peter Opahle
I used VS 2010 for the sample. If you are using older version of Visual Studio, you could run directly project file : UltraSplitterPanels.
Please if you have any questions, do not hesitate to ask me
Regards
opps i guess i should have been more specific what version of Visual Studio is the solution in?
Could you please take a look at the new attached sample. The new sample is version 10.2, the previous was 10.3
What version is your sample solution in?
Hi Peter,
It is possible to use more than 1 splitter in one panel as it shown at the attached sample. The splitters are set from top to the bottom of the UltraPanel.
