65
Exception by group by column
I have a grid with 3 column e.g. select, person and old .
I can disable the cell "select" Grid1.Rows[0].Cells["Select"].Activation = Activation.Disabled
this work fine.
And now  if I group the Grid by the column person , there is exception because Grid1.Rows[0].Cells is null.
How can I fix this bug?
Habib
  • 69832
    Grid1.Rows[n].Cells cannot possibly return null because the Cells property automatically creates an instance and returns it. If you are accessing Grid1.Rows[0].Cells at a point when there are no rows, that would cause an IndexOutOfRangeException; the way to remedy this is to check Grid1.Rows.Count before accessing any members. Generally speaking, the way to prevent a null reference exception is to check for null before accessing any object that can be null.
