100
Formatting the header row of a sorted column grouping.
I am manually adding sorted goups with the following code to a wingrid.
Band.SortedColumns.Add(Column, SortDescending, SortGroupBy)
SortDescending and SortGroupBy are booleans that are being set in code based upon data in the DB.  When I create a 'Grouping' like this, how do I access the Header Row that is created.  I need to set some of it's appearance properties(Backcolor, FontData, etc.)
Thanks for any advice...
