1105
How to make tabheader unfocusable?
I would like that when a user clicks s tab header or the tabheader gets focused that the first control in the tabpage gets the  focus.
Is there an event which I can subscribe to?
Can a set the tabheader to focusable false?
regards
Stefan
  • 9298
    Stefan,
    You could disable the tab by setting the Enabled property of the tab to false.  Would that do what you want?
    You can handle the SelectedTabChanged event and then depending on what tab is selected you can set the focus to the control you want.
    Something like the following:
    private void ultraTabControl1_SelectedTabChanged(object sender, Infragistics.Win.UltraWinTabControl.SelectedTabChangedEventArgs
    e)
    if
    (ultraTabControl1.SelectedTab.Index == 0)
    ultraGrid2.Focus();
    else
    if
    (ultraTabControl1.SelectedTab.Index == 1)
    ultraGrid1.Focus();
    Let me know if that helps
    Michael S.
