215
Random InvalidOperationException in using UltraWinToolbars
I'm using ultrawintoolbars(version 9.2.20092.2017) in a project (VS.net C# windows app).Randomly I get the error "the object is currently in use elsewhere."
Below is the stack trace:
 ************** Exception Text **************
System.InvalidOperationException: the object is currently in use elsewhere.
   at System.Drawing.Image.get_Width()
   at System.Drawing.Image.get_Size()
   at Infragistics.Win.UltraWinToolbars.PopupToolBase.CalculateLogicalSizeOfToolInstance()
   at Infragistics.Win.UltraWinToolbars.PopupControlContainerToolBase.CalculateLogicalSizeOfToolInstance()
   at Infragistics.Win.UltraWinToolbars.ToolBase.CalculateLogicalSizeOfToolInstanceHelper()
   at Infragistics.Win.UltraWinToolbars.ToolBase.CalculateHeightResolved(Boolean useCalculateLogicalSize)
   at Infragistics.Win.UltraWinToolbars.ToolBase.get_Height()
   at Infragistics.Win.UltraWinToolbars.UltraToolbarBase.ToolGroup..ctor(ToolbarMetrics metrics, ToolBase firstVisibleTool)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarBase.ToolbarMetrics.CalculateFloatingMetrics(Size cachedSize, Size delta)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarBase.GetMetrics(Size cachedSize, Size delta)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarBase.ToolAreaInformation.FromToolbar(UltraToolbarBase toolbar, Rectangle overallArea)
   at Infragistics.Win.UltraWinToolbars.ToolbarUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  • 71886
    Hello wangchanel,
    I did some research about this issue. I made it clear to myself that this might be caused by a bug in the framework, fixed in the latest versions. The following is a quote from Andrew Smith regarding the same type of exception throwed with a red drawed symbol similar to an 'X' in place of a control:
    This sounds like a very old issue that I thought was worked around in a hotfix although v2 is a very old version and its possible that the issue was reported and worked around (its actually an issue in the .net framework) in a later release.
    You could take a look at the following thread too: http://forums.infragistics.com/forums/p/9284/88839.aspx. This kind of issue is discussed there also.
    Please do not hesitate to ask if something comes up.
