Hello all,
It has been a while since we last upgrade our NetAdvantage Infragistics WindowsForms Volume License. Does anyone even remember working with Infragistics NetAdvantage Vol 5.2? :)
We've finally decided to go trough with Vol10.3 first, in order to give a new "look and feel" to our erp, improve infragistics components and routines and mostly because we're convinced that this Vol. meets some of the requirements we need to accomplish in short term.
We've tried to upgrade our projects by using the Upgrade Utility that ships with Vol 10.3 without success...
"No matching assembly located in available assemblies Infragistics2.Win.v10.303:20:11: at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyList.FindNewAssemblyNode(String assemblyName) at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)"
Our project files don't have readonly attribute active. We're using VS2008 in x64 environment.
We've read something about this issue submitted by others in your forums and they didn't get much of assistance. We don't find reasonable and logic upgrading more than 30 projects (in one solution only) by hand.
Can you please assist?
Thanks in advance,
PM
Hello PM,
I am not sure what might be wrong with your scenario but I have tried to upgrade old project containing 8.2 (since this is the oldest that I have) and I was able to upgrade it using the latest service release for NetAdvnatage 2010 vol3. What you could do is try installing the latest service release available for your version NetAdvnatage 2010 vol3 and verify if the behavior remains the same. Also please verify that all of the assemblies are installed correctly in your GAC if you are reffer the assemblies from there.
Please let me know if you have any other questions.
