678
Drag and Drop over 2 ultragrids in 2 differents tabs
I need two thinks :
1- I need to drag and drop on the same ultragrid but far from initial position. The problem is that the scrollbar do not move automaticaly on the left or right. If i need to copy cell 1 to the destinaton 50, the scroolbar don't move.
2- I need to drag and drop over two ultragrids and two differents tabs as on my picture below.
I want to copy cell from ultragrid1 in tab (1- Allée 1) to second tab (2- Allée 2).
Thanks for your help.
  • 469350
    Verified Answer
    If that's the case, then you would need to implement that yourself using the DragOver event. You would probably do something like detect when the mouse is near the right edge of the grid and then scroll the grid using the grid.ActiveColScrollRegion.Scroll method.
    Again, I think you would have to implement this yourself. I guess you would trap the DragOver event of the tab control and when the mouse is dragged over the tab, you would switch to that tab by setting the SelectedTab property on the UltraTabControl.
