435
Datarow delete causes error
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
The following error exists in ultrawingrid version 10.2 and 10.3.  It does not exist in version 8.3.
We are running into an error that has been hard to pinpoint, but the following source allows you to see a scenario where the error happens every time.  First, in the ultrawingrid InitializeLayout event we set the ExpansionIndicator and LoadStyle.
Notice in the btnRemoveChildRecordAndCrash click event a parent record is activated and then a child row is deleted.  The button click event generates the following error when _p1c1.Delete() executes.
Object reference not set to an instance of an object.
The  btnRemoveChildRecordWithoutCrashing click event does the exact same thing without activating a row.  Execution is completed without error.
If you comment out one or both of the properties set in the InitializeLayout event the error does not occur.
The row activation does not need to be in the button click event.  The error will also occur if it is in the form load or somewhere else.
Please help?
Public Class Form1
    Private _dataset As New DataSet
    Private _childTable As New DataTable("ChildTable")
    Private _parentTable As New DataTable("ParentTable")
    Private _p1c1 As DataRow
    Private WithEvents ugBasicGrid As New Infragistics.Win.UltraWinGrid.UltraGrid
    Private WithEvents btnRemoveChildRecordAndCrash As New Button
    Private WithEvents btnRemoveChildRecordWithoutCrashing As New Button
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Me.ClientSize = New System.Drawing.Size(662, 404)
        Me.ugBasicGrid.Location = New System.Drawing.Point(12, 12)
        Me.ugBasicGrid.Name = "ugBasicGrid"
        Me.ugBasicGrid.Size = New System.Drawing.Size(619, 315)
        Me.Controls.Add(Me.ugBasicGrid)
        InitializeDataSet()
        ugBasicGrid.DataSource = _parentTable
        Me.btnRemoveChildRecordAndCrash.Text = "Remove Child Record (and crash)"
        Me.btnRemoveChildRecordAndCrash.Location = New System.Drawing.Point(12, 344)
        Me.btnRemoveChildRecordAndCrash.Size = New System.Drawing.Size(184, 23)
        Me.Controls.Add(Me.btnRemoveChildRecordAndCrash)
        Me.btnRemoveChildRecordWithoutCrashing.Text = "Remove Child Record (no problem)"
        Me.btnRemoveChildRecordWithoutCrashing.Location = New System.Drawing.Point(200, 344)
        Me.btnRemoveChildRecordWithoutCrashing.Size = New System.Drawing.Size(184, 23)
        Me.Controls.Add(Me.btnRemoveChildRecordWithoutCrashing)
    End Sub
    Private Sub InitializeDataSet()
        _dataset.Tables.Add(_parentTable)
        _parentTable.Columns.Add(New DataColumn("ParentID", GetType(Integer)))
        _parentTable.Columns.Add(New DataColumn("ParentDescription", GetType(String)))
        _parentTable.Rows.Add("1", "parent one")
        _parentTable.Rows.Add("2", "parent two")
        _childTable.Columns.Add(New DataColumn("ParentID", GetType(Integer)))
        _childTable.Columns.Add(New DataColumn("ChildID", GetType(String)))
        _childTable.Columns.Add(New DataColumn("ChildDescription", GetType(String)))
        _p1c1 = _childTable.Rows.Add("1", "p1c1", "parent one child one")
        _dataset.Tables.Add(_childTable)
        _dataset.Relations.Add("Relation", _dataset.Tables("ParentTable").Columns("ParentID"), _dataset.Tables("ChildTable").Columns("ParentID"), False)
    End Sub
    Private Sub btnRemoveChildRecordAndCrash_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnRemoveChildRecordAndCrash.Click
        If _p1c1 Is Nothing Then
            MsgBox("please restart the program before clicking any more buttons.")
            Return
        End If
        ugBasicGrid.Rows(1).Activate()
        _p1c1.Delete()
        _p1c1 = Nothing
        _childTable.AcceptChanges()
        MsgBox("Child row removed.")
    End Sub
    Private Sub btnRemoveChildRecordWithoutCrashing_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnRemoveChildRecordWithoutCrashing.Click
            Return
        End If
        'ugBasicGrid.Rows(1).Activate()
        _p1c1.Delete()
        _p1c1 = Nothing
    End Sub
    Private Sub ugBasicGrid_InitializeLayout(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles ugBasicGrid.InitializeLayout
        ugBasicGrid.DisplayLayout.Bands(0).Override.ExpansionIndicator = Infragistics.Win.UltraWinGrid.ShowExpansionIndicator.CheckOnDisplay
        ugBasicGrid.DisplayLayout.LoadStyle = Infragistics.Win.UltraWinGrid.LoadStyle.LoadOnDemand
    End Sub
End Class
