570
ValueBasedAppearance (Formula Condition Across Bands)
Has anyone tried to apply a formula condition across bands? I am trying to check for the existence of  particular band on the grid (underlying datasets are related by a FK relationship).
I'd like to highlight a cell in the parent band yellow when the child band for that particular row is populated. I'm attempting to do this w/ a formula similar to the following:
not(isdbnull( [../fk_tradeexecution_canceltradeexecution/cancelexecutionid] ))
(fk_tradeexecution is my child band, cancelexecutionid is the key relating the two bands)
Not sure why this doesn't work.... If there are child bands for the row, then a call to isdbnull should return false and hence should highlight the cell yellow......
If tried replacing isdbnull with isnull, I've even tried replacing isdbnull with a count() function and checking to see if the count is <> 0.... no luck in either situation.
As an aside, I definitely have an UltraCalcManager on the grid...
