I opened up a VS 2010 solution file in the Version utility to upgrade a solution and its corresponding projects and files that had been running with the Infragistics 2009.2 libraries.
However the Version utility seems to require read/write access to files that are included in the file folder hierarchy including backup files which are not referenced, either directly or indirectly via the solution file I have selected to be upgraded. It would appear based on the files that are being referenced by the utility that it will be upgrading a lot more files and projects than what I need or want it to.
Is there any way the behavior of the Version utility can be modified to only access projects and files that are directly referenced via the specified solution file?
I have sent the feature request details to your email address.
Please let me know if you have any questions on this matter.
Currently this feature is not available with Version Utility. I will go ahead and log it as a feature request and I will send you the feature request details either by end of day today or tomorrow.
