Hi, is it not possible to set the orientation to horizontal in the explorer??
At the moment i use the UltraListBar there you can set it to horizontal. but in the ultralistbar i cannot disable an item
ok thanks that was what I was expecting. would be fine if its in the next releases :)
Currently UltraExplorerBar does not support this feature. I will go ahead and log this as feature request for you.
Hi i would have the same behavior with the explorer bar as with the UltraListBar1(see attach picture)above i have the explorerbar which should be horizontal like the bottom ultralistbar. at the moment i
have only vertical .
Sorry , in this thread i have 2 questions.first how to set the orientation of the winexplorerbar to horizontalsecond question is how to enabled or disable to click / select an item in a group.
You can disable an item independently of the view using the UltraExplorerBarItem.Settings.Enabled property. I do not understand what you mean by horizontal orientation in this context.
