hi,
i need to use a different editor with different properties (MinValue, MaxValue, etc) for each cell in the grid
so i listen to InitializeRow event and did somthing like this
ProfileProperty property = (ProfileProperty)e.Row.ListObject;if (property.Type == PropertyTypeEnum.SingleValue) { --> CreateEditor(property, e.Row.Cells["Value"]); <--e.Row.ExpansionIndicator = ShowExpansionIndicator.Never; }else if (property.Type == PropertyTypeEnum.MultiValue) { e.Row.ExpansionIndicator = ShowExpansionIndicator.Always; }
ProfileProperty property = (ProfileProperty)e.Row.ParentRow.ListObject; --> CreateEditor(property, e.Row.Cells["Value"]); <--
switch (property.ValueType) {case PropertyValueTypeEnum.Boolean: CreateBooleanEditor(property, cell);break;case PropertyValueTypeEnum.Date: CreateDateEditor(property, cell); break;case PropertyValueTypeEnum.Float: CreateNumericEditor(property, cell);break;case PropertyValueTypeEnum.Integer: CreateNumericEditor(property, cell);break; }
break;
UltraNumericEditor intEditor = new UltraNumericEditor(); ((ISupportInitialize)intEditor).BeginInit(); // Set the value bounderiesif (property.Min != null) intEditor.MinValue = property.Min; if (property.Max != null) intEditor.MaxValue = property.Max; // determine the editor data typeswitch (property.ValueType) {case PropertyValueTypeEnum.Integer: intEditor.NumericType = NumericType.Integer;intEditor.MaskInput = "nnnnnnnnn"; break;case PropertyValueTypeEnum.Float: intEditor.NumericType = NumericType.Double;intEditor.MaskInput = "{{double:9.3}}";break; }if (property.DefaultValue != null) { intEditor.Nullable = true; intEditor.NullText = property.DefaultText; }intEditor.PromptChar = ' '; intEditor.ReadOnly = property.ReadOnly;intEditor.MaskDisplayMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.Raw; intEditor.MaskClipMode = Infragistics.Win.UltraWinMaskedEdit.MaskMode.Raw;intEditor.Name = property.Name + "editor";((ISupportInitialize)intEditor).EndInit(); cell.EditorControl = intEditor;
UltraDateTimeEditor dateEditor = new UltraDateTimeEditor(); dateEditor.ReadOnly = property.ReadOnly; cell.EditorControl = dateEditor;
UltraCheckEditor boolEditor = new UltraCheckEditor(); boolEditor.Enabled = property.ReadOnly; cell.EditorControl = boolEditor;
for each row in the grid i created an editor control and set the " Value " cell editor with that control
its workin OK but the editors dose not work as i set them to work, like the NumericEditor show me the prompt char '_' insted of ' '
and when in double numeric type the input is displayed like this ' {________ . ___ } '
am i doin something wrong?
i just cant loose those prompt chars
and when i use the checkbox editor its not centerd in the cell and i could not find a property witch set it centered
moshe
nst972 said:and is there a way to make the checkbox centered?
You would have to do that via a property on the editor or editor control. I'm pretty sure UltraCheckEditor has a property for CheckAlign.
The grid column has it's own PromptChar and other mask properties. To get it to pick up the mask properties of the editor, you have to set UseEditorMaskSettings on the column to true.
