Using Infragistics v8.2
All,
I'm currently working on an application which has form validation. One of the fields uses a specific UltraValidator to ensure that the validation is between 1 and 365:
private void SetValidation() { m_cycleValidator = new UltraValidator(); m_cycleValidator.ValidationTrigger = ValidationTrigger.Programmatic; ValidationSettings settings = m_cycleValidator.GetValidationSettings(m_ratingNextReviewTb); settings.Reset(); settings.Condition = new RangeCondition(1.0, 365.0, Type.GetType("System.Double")); settings.NotificationSettings.Caption = "Next Review Cycle must be between 1 and 365 days."; settings.ValidationPropertyName = "Text"; settings.IsRequired = false; settings.EmptyValueCriteria = EmptyValueCriteria.NullOrEmptyString; settings.NotificationSettings.Image = Properties.Resources.incomplete; }
The issue is that when this validator is set on the control (m_ratingNextReviewTb) the UserControl can never be released.
Looking at the dotTrace output from my memory profiler, it appears that there is an unusedValidationResult stored in Infragistics.Win.Misc.ValidationManager which refers back to my ValidationSettings which referers back to my UltraTextEditor which is holding an event handler back to my user control. Because of this, It can't be garbage collected.
This unulsedValidationResult i believe is being created when the control is painted and it is calling IsValid() to determine how it should draw the control (putting the image icon, for example). if I don't set this validation settings on the UltraTextEditor, the unusedValidationResult object is not allocated and then there's no root path back to my Control so it can get garbage collected.
My question is: how can I dispose of this 'unusedValidationResult' instance that's behing held by Infragistics.Win.Misc.ValidationManager so that there is no Root path back to my user control and it can get garbage collected?
Note: I could go to the ultratexteditor (m_ratingNextReviewTb) instance in my user control and figure out how to remove the event from it to my userControl, but that's not fixing the leak to the UltraTextEditor instance. The core problem is i need to get rid of the refernce held by ValidationManager.
Can anyone help with this?
Hello Jankol,
Would it be possible for you to provide us, the application that you are testing, or a similar one, that behaves the same, so we would be able to test and see your current scenario at our end and research it further for you.If you have any other questions please feel free to let us know.
We are using Infragistics 11.2.
I am also using MemoryProfiler 4.0 to find potential memory leaks in our application.
As it seems, all of our forms and usercontrols, are Disposed after closing them, but not GarbageCollected due to the referanse to ValidationManager, so they stay in memory.
The issue here was in the version used - NetAdvantage for Windows Forms2008 vol2 which has an issue which has been fixed in some point, and it was verified there weren't such issues with NetAdvantage for Windows Forms 2010 vol.3Could you please let me know what version of the Infragistics controls you are currently using in your application? Also please take a look at our product lifecycle page at :
http://ko.infragistics.com/support/product-lifecycle.aspx#ProductLifecycle
Do any of you care to share the results with others?
I am having simmilar issues with the ValidationManager having too many references to other controls that are disposed but not garbage collected because of Validation manager.
Hello Cris,
Thank you for the sample.
Just to let you know that you would be able to find your case in our system following the steps below:
1.Go to www.Infragistics.com
2.Hover over "My IG" and click "My Support Activity".
3.Under the "Active" Tab you would be able to find your case.
Once I have more information for you I will update you here or through your case.
