Hi
I have an UltraWinGrid with SupportsDataErrorInfo switched on for cells. This works fine, changing the BackColor of the cells which have an error.
The problem is I need to still see this different / highlighted back color when the user has the whole row selected. At the moment, the BackColor of the SelectedRow Appearence completely overrides it.
I have tried many ways to get the Error Backcolor to show through, changing transparency and alpha levels but have had no luck.
Any help you could give me would be greatly appreciated.
Martin
This works perfectly!!
Many thanks.
Hi Martin,
I recommend that you turn on the selection overlay.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.SelectionOverlayColor = SystemColors.Highlight; }
This will make the grid's selected rows appear with a semi-transparent overlay so that you can still see the colors of the cells in the row.
