I have tried to view onen sample, but found it hard to follow - sorry documentation would have been most helpful.
Anyway - I am trying to add a button to the child band - tried these two lines - but close.
A new column does get added but is just a text box - not a button.
any code changes/missing code would be helpful to get this to work -- THANKS
Me.UltraGrid1.DisplayLayout.Bands(1).Columns.Add(ColumnTypeNames(0))
I'm not sure I understand your question. You are adding a new, unbound column to the grid and passing in an array of strings as the name of the column - why? What are you expecting that to do?
If you want a button column in the grid, add an unbound column like you are doing (except you will probably want to give it a m0ore reasonable name). Then set the Style property on the column to Button.
