When designing the grid, in column arrangement designer, i add groups add drop columns in that groups, than i set the property ColHeaderVisible to false, now only group headers are visible, but i cannot sort them by clicking on them. Is there any way to sort the rows when Columns Headers are not visible.
hi please check the attached. it's using infragistics v. 9.2
so if you have a newer version you have to upgrade this project.
it's about adding a context menu strip that will work on right click on a cell
hope this helps
Plz .. can you elaborate it as i am unable to understand how u can do sorting on grid using Context Menu Strip
you can add a context menu strip to the grid and include the sorting in it
