200
disable selection in ultragrid
Hi.
I am sure this is an easy boolean fix... I just can't find it :)
I have 2 grids. One is updated upon selection of the other. Ny problem is, that I cannot make one of the grids "unselectable". Thus when the user clicks on a row/cell the selection should not be seen. I've looked for some overrides, hooked on events to set handled flags and even tried making selection (and activerow) transparrent.
So to sum it up: Where do I find this sweet little tiny boolean that disbles selection in a grid?
Hykkel
  • 5520
    Suggested Answer
          ultraGrid1.DisplayLayout.Override.SelectTypeCell = SelectType.None;
                ultraGrid1.DisplayLayout.Override.SelectTypeCol = SelectType.None;
                ultraGrid1.DisplayLayout.Override.SelectTypeRow = SelectType.None;
