485
Add a node with both a text string and a progress bar?
Is it possible to create a node that has both a text string and a progress bar? If so, how?
As an alternative, I've heard that a node can have a text string followed by an image. I could fake the progress bar by creating an image of a progress bar but I don't know how to associate an image to the right of the text string. How is this done?
Rick
  • 469350
    Verified Answer
     Hi Rick,
        You might be able to do this using a CreationFilter, but it would not be trivial. Unless you want the text to appear IN the progressbar. But it sounds like you want text to the left of the bar.
        You would do this using the cell Appearance. A good place to set this is in the InitializeRow event of the grid. You can assign an Image to the Appearance and also set the ImageHAlign to Right.
