On the utraToolbarsManager control, i have two PopupMenuTools with DropDownArrowStyle as standard.
Each tool contains submenus with three ButtonTools.
When I right click on first ButtonTool in first PopupMenuTool (default context menu is displayed) and immediatly left click on second PopupMenuTool, the two submenus are displayed at the same time.
Could you please let me know what settings i should do.
Hello Sharda,
I have tried this on the same environment and I am not able to reproduce this behavior. Could please provide me small sample reproducing this behavior so I will be able to research it further for you.
Sorry for late reply. I am using NetAdvantage 2010.3 and working on Windows XP SP3.
Sharda.
I am still following your issue. Have you been able to verify what is the version of the NetAdvantage that you are using? Is there any service release applied to it? What is the current environment that you are using your applicaiton on?
I have tried it, and I am not able to reproduce it.
Please let me know if you have any other questions.
Could you please let me know what version of NetAdvantage you are using? Is there any service release applied to it?
