I can create a new form, set the IsMdiParent = True, then add an UltraFormManager component to manage the appearance of the form.
However, when I try to add an UltraToolbarsManager to the form, I get the message indicating that the DockWithinContainer can not be set as dock areas have already been added. How do I add a toolbar or is this not possible? (I can't find anything anywhere that references this)
Dave
Hi Dave,
Thanks for that - that works perfectly.
Hello dwdavies,
You can't have both the FormManager and the ToolbarsManager on the same form because the FormManager is a subset of the ToolbarsManager. To style the border of the form using the UltraToolbarsManager, set the FormDisplayStyle of the UltraToolbarsManager to either RoundedFixed or RoundedSizable.
