340
Change the default selection in grid on load
Hi, How to cahnge the default first row selection in ultrgrid on load of the form? Thanks, swetha.
  • 5520
    Verified Answer
    if you are not using the event afterRowActivate.. this will help
     private void ultraGrid1_AfterRowActivate(object sender, EventArgs e)
                ultraGrid1.ActiveRow = null;
                ultraGrid1.Selected.Rows.Clear();
                ultraGrid1.AfterRowActivate -=new EventHandler(ultraGrid1_AfterRowActivate);
    it will remove selection and activation the first time, then the event is removed
    hope this helps
