225
Custom summary rows
I am trying to replace the standard summary row so that all TaskUIElements of subtasks are drawn in the summary task row. I tried the DrawFilter and had some luck with that: As soon as the summary is drawn (DrawElement-Method) I get the UIElements of the subtasks, offset them to the Y-position of the summary and call DrawElement of the subtask UIElement. Then I offset the subtasks back to their normal position and let them draw the regular way.
Code looks like this:
public bool DrawElement(Infragistics.Win.DrawPhase drawPhase, ref Infragistics.Win.UIElementDrawParams drawParams)
 Task t = (Task)drawParams.Element.GetContext(typeof(Task), true);
 if (t != null && t.IsSummary)
  foreach (Task tsub in t.Tasks)
   UIElement tsubUI = this.ultraGanttView1.UIElement.GetDescendant(typeof(TaskUIElement), tsub);
   if (tsubUI == null)
    continue;
   int deltaY = drawParams.Element.Rect.Y - tsubUI.Rect.Y;
   tsubUI.Offset(0, deltaY);
   tsubUI.DrawElement(ref drawParams);
   tsubUI.Offset(0, -deltaY);
  return true;
The only problem is, that as soon as I close up the summary in the grid part of the UltraGanttView, no UIElements are created for the Subtasks. I understand that behavior, but is it possible to create TaskUIElements manually for the subtasks like the GanttView would do and paint them in the summary row? I have tried this but can't figure out the correct TaskUIElement.Rect dimensions. As soon as I create the TaskUIElement for the subtask the Rect is 0,0,0,0. Is there a way to calculate the dimensions of the rectangle?
