205
GroupBy and retrieving Rows
I ran into a problem where I have a grid which is populated with a BindingList<> of simple objects. I would have a user then click a button and I would iterate over the Grid.Rows property retrieving cell information, all was good until I enabled GroupBy.
I then found that the Grid.Rows collection now only had one row in it with IsGroupBy set to true and a hierarchical tree of data now available via its ChildBands property - dependant on howmany times the user decided to GroupBy.
Is there a way where I can still allow users to GroupBy but still access the flat hierarchical data as I was before? Instead of what I am guessing is going to be a recursive tree walk? Note I used an unbound column in my data so accesing the datasource directly I believe won't help.
Any ideas - as I am sure there has to be an easier way and that I am over complicating things?
If it helps clarify I have a list of people and an unbound boolean column  to select those people. I then wish to iterate over the rows and pull data out if the unbound column is checked or not. This I can do, the only snag is there are other columns available for the person for which the user can group by - but I still wish to iterate over the full list of people and using the unbound column value retrieve their details.
