665
TabStrip not HotTracking correctly when controls overlap
I am using an Infragistics.Win.UltraWinTabControl.UltraTabStripControl in VS2010.
I use the AppStylist to set the HotTracking appearance of the tabs. The TabStrip is positioned such that a panel containing some buttons is below slightly overlapping it (The panel is in front). Sometimes  when I move the mouse from a tab (which correctly highlights when hotTracked) down to the panel below (especially when I move the mouse slowly) the hotTrack appearance stays and does not revert to the normal appearance as it should.
Is there a method I can use to force the TabStrip to refresh the tab appearances correctly.
I have tried Refresh() and Invalidate() without success.
Paul
