265
UltraTabControl and UltraTabstrip control truncate caption when bold.
Hi;
In 20103.2056 - Whenever I set the caption for a Tab in either of these two controls, the tab correctly expands to accomodate the text.
However if I then change the appearance font to bold, then the tab does not resize any further, and consequently the text is truncated in the tab.
Kindest Regards
Dave Ballantyne
  • 48586
    I have created a support ticket for you with id CAS-60920-NV7FLH to be able to investigate this issue further for you. I will update you via the case as soon as I have information for you.
    Thank you .
