265
UltraGrid (and other Ultra contol) IDE errors after installing SR 201003.2056
Hi There;
I have just upgraded from 20103.1000 to 20103.2056 and am now having huge problems in the VS2008 IDE, especially in relation to dropping data source objects on a form.  The problem is not restricted to the grid, but rather to all IG controls that are bound to datasource members in the IDE.
It is the case that I have customized my data source members to utilize infragistics controls by default.  After the upgrade, whenever I now drop a control on a form, the control appears both on the form itself and in the form's tray (i.e. where components are normally placed).  If you delete the component from the tray, then the component is removed from the form as well.  I refer you to this post which describes a similar problem:
     http://forums.infragistics.com/forums/p/42616/235057.aspx#235057
The differences for me from the above post are:
  1. Removing and replacing the references does not solve the issue.
  2. The issue is not restricted to existing projects.  New projects are affected as well.
  3. If I drag an UltraXXX control directly from the toolbox, it works just fine.
  4. The problem also occurs in VS2010, even with a new project.
In addition, I reffer you to an earlier post of today regarding a similar situation when you attempt to drag ANY databound control onto an UltraPanel control.  My post is at:
    http://forums.infragistics.com/forums/t/52216.aspx
It appears that there are some major issues regarding databound controls in the IDE.  This is a serious problem and I would appreciate any help that you can provide.
Heeeeeeeelp
Kind Regards
Dave Ballantyne
