I have 2 controls in a toolbar. (Two textboxes). When I hit tab, it does not go from textbox1 to textbox2..it goes to the next control (a ultratree under the toolbar).
I swear there was setting for this, but I can't remember =(.
Thanks.
Michael,
I have submitted this issue to our development team for further review. The reference number for this item is 128486. You will receive more information through the support case that I mentioned above.
I want you to know that I have reproduced the behavior that you are referring to. I have opened a new support case for you. Its reference number is CAS-105361-M9Q8P9. I am going to submit this issue to our engineering team along with a sample that reproduces the issue. I will get back to you as soon as I have done so and you will receive more information through the support case.
So I created a new form and laid it out like the formI am having an issue with and I was able to reproduce the issue.
I have attached the form.
I see now that I had already posted the isolated behaviour. I guess I will try to rebuild the form from the groud up. Our project is huge and highly involved so it is not easy for me to post the code here.
Sorry for the delay in the response...we have a lot going on at our company =).
So as mentioned the ultratoolbaManager is sitting in a shared tab page of an ultra tab control. When i hit tab on any tool item it goes down the control inside of the selected tab. If i take the toolbar OUT of the shared tab page and let's say put it on the form or something it tabs from control to control just fine.
What do you think?
