4032
Problem with two UltraDropDown dependent Columns
I have two columns of style DropDownList. I have implemted this like it is advised in another post and example( handling BeforeCellListDropDown- and AfterCellUpdate-events). This works ok so far.
The the first drop-down contains two entries: DayOfWeek or DayOfMonth. If I do so the value list in the second drop-down is filtered properly and the user can choose a DayOfWeek Sunday ... Saturday (0..6) or DayOfMonth (1..31).
After saving the data, when the form comes up the next time, choosen DayOfMonth between 1 and 6 are displayed as DayOfWeek instead. In the drop down list, only 1..31 ist displayed, because this is filtered in the BeforeCellListDropDown event handler. Actually, the cell shows a value that is not in the list.
I set the column style to DropDownValidate in the Grid_InitiallizeLayout event-handler but does not help.
Which is the best way to solve this problem? Shoul I handle another event?
Thanks for any help.
Markus
