615
How to set Particular cell value to Empty in Vb.net 2010?
For Example:
  ultragrid.Rows(i).Cells(0).Value = DBNull.Value
or
  ultragrid.Rows(i).Cells(0).Value = Nothing
From the above, Which will u recommend to use it?
                    If i set 'Nothing'  then it creating Exception for the first row of the grid. For the other rows it works fine.
  • 69832
    Verified Answer
    The System.Data.DataColumn class exposes an AllowDBNull property which determines whether that column supports null values. If you are bound to a DataTable, your problem is most likely related to this.
    'Nothing' is the VB equivalent to null in C#, and is different from DBNull.Value. Again, if you are bound to a DataTable you usually use DBNull.Value as opposed to null.
    Note that UltraGridColumn exposes a Nullable property which determines how the grid interprets the act of clearing a cell's value.
