First of all sorry if I posted in the wrong newsgroup. I amtrying to use the Pivot Grid for the first time. I am populating a Datatable from my database and on of the fields is a DateTime. I then add the field to the Pivot grid using the code below
PivotGridField myField = new PivotGridField("FlightDate", PivotArea.FilterArea);
myField.Caption = FieldTitle;
pivotGridControl1.Fields.Add(myField);
This works but the Field comes out as '12-31-2010 00:00:00' but i need to format the date to UK format with no time 'dd/MM/yyyy'. I tried to use the code below but with no luck
myField.CellFormat.FormatType = FormatType.DateTime
myField.CellFormat.FormatString = "d";
Am i doing something wrong or the date cannot be formatted
This forum is for Infragistics controls.
I am using a DevExpress.XtraPivotGrid in a WinForm Application
Hi
There is no PivotGrid in the Windows Forms product line. So I think you are posting in the wrong forum.
I'd be happy to move your post to the appropriate forum, but I'm not sure which one that is.
What programming environment are you working in? WPF? Silverlight? ASP.Net?
