350
Application Menu 2010 and ISL Files
Testing with a beta version for windows forms I found that I can not "mix" style file. ISLwith the characteristics of application menu 2010.
When I apply the style sheet this tab or tab in the ribbon (File, by default) tends to disappear.
Is it a normal behavior or due to some configuration?
If some configuration, how I can fix it?
In advance, thank you very much
  • 71886
    I believe that this is expected behavior since the AppStylist's styles are overriding any other setting in the application. If you want to somewhat mix styles you would have to alter an isl file and turn it to whatever style suits your needs. You could do that using the 'AppStylist' software which manages the isl files.
    Please do not hesitate to contact us if you need any additional assistance.
