195
Custom Legend location
Hi;
 Is it possible that I can custom the legend's location? I saw only 4 locations currently available (top, left, right, bottom), and i can  not drag the legend icon to the location I prefer, such as in the middle of the chart.
 If it is, how can i implement?
thanks ...
  • 28496
     here's a simple example using the FillSceneGraph event to get you started.  if you are using version 7.2 or earlier, you will need to move this code into a class implementing ILayer, as the FillSceneGraph event is new to 7.3.
    private void ultraChart1_FillSceneGraph(object sender, FillSceneGraphEventArgs e)
    int legendBoxX = (int)(this.ultraChart1.Width * .7);
    int legendBoxY = (int)(this.ultraChart1.Height * .1);
    int legendBoxW = (int)(this.ultraChart1.Width * .25);
    int legendBoxH = (int)(this.ultraChart1.Height * .5);
    Box legendBox = new Box(new Rectangle(legendBoxX, legendBoxY, legendBoxW, legendBoxH));legendBox.PE.Fill = Color.Yellow;
    e.SceneGraph.Add(legendBox);
    LabelStyle legendLabelStyle = new LabelStyle();
    int legendItemX = (int)(legendBoxX + legendBoxW * .1);int legendItemY = (int)(legendBoxY + legendBoxH * .1);
    int legendItemW, legendItemH;
    legendItemW = legendItemH = (int)(legendBoxW * .2);
    int legendItemSpace = (int)(legendItemW * .25);
    int legendItemTextX = legendItemX + legendItemW + legendItemSpace;
    int legendItemTextW = legendBoxX + legendBoxW - legendItemTextX;
    Box legendItem1Box = new Box(new Rectangle(legendItemX, legendItemY, legendItemW, legendItemH));legendItem1Box.PE.Fill = Color.Red;
    e.SceneGraph.Add(legendItem1Box);
    Text legendItem1Text = new Text(new Rectangle(legendItemTextX, legendItemY, legendItemTextW, legendItemH), "Item A", legendLabelStyle);
    e.SceneGraph.Add(legendItem1Text);
    legendItemY += legendItemH + legendItemSpace;
    Box legendItem2Box = new Box(new Rectangle(legendItemX, legendItemY, legendItemW, legendItemH));legendItem2Box.PE.Fill = Color.Blue;
    e.SceneGraph.Add(legendItem2Box);
    Text legendItem2Text = new Text(new Rectangle(legendItemTextX, legendItemY, legendItemTextW, legendItemH), "Item B", legendLabelStyle);
    e.SceneGraph.Add(legendItem2Text);
  • 266
    So far as i know there isnt a "custom location" mode with x/y positioning for legends. What i have been doing is just using the margin offsets. So you set the location general position (left/right/top/bottom) then offset as you need from there.
    <Legend Location="Right">
         <Margins Bottom="15" Right="0" Top="10" />
    </Legend>
    If you're after something particularly special then you could drop down to making your own layer to create your own legend using primiatives - text polygons etc.
