1330
Firing The InitializeLayout Event
Is there away to fire the Initialize layout event again after it's already fired?  Or perhaps I am using the control incorrectly.
The reason I ask is becuase when I make a call to the backened procedure the data changes however this change is not reflected in the UltraGrid I am using.
I should note that I am using a customized solution I found on the I-net where the ultra grid is modified to show records in a sort of 'Tree' hierarchy.  This is the main reason that it is important to call Initialize Lyaout again.
Hope this makes sense.  Thank you.
  • 69832
    If the grid is not reflecting changes to the underlying data, something is probably going wrong, so the best approach is to find out why that is. To answer the question, you can assign null to the control's DataSource, then set it back to reference the data source; this will refresh the grid since it will be forced to reload the data.
