I got this error on my (normally stable) application after it had been running overnight. Attached is a stack trace. Could it be a bug in the toolbar?
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: Visual Styles-related operation resulted in an error because no visual style is currently active. at System.Windows.Forms.VisualStyles.VisualStyleRenderer.IsCombinationDefined(String className, Int32 part) at System.Windows.Forms.VisualStyles.VisualStyleRenderer..ctor(String className, Int32 part, Int32 state) at System.Windows.Forms.VisualStyles.VisualStyleRenderer..ctor(VisualStyleElement element) at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureTextGDIOrThemed(String text, Font font, TextFormatFlags textFormatFlags) at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureCharacterRangesGDI(String text, Font font, TextFormatFlags textFormatFlags, CharacterRange[] ranges) at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.ReMeasureParts(String text, Int32[] parts, Single[] widths, Int32 partStartIndex, Int32 partEndIndex, Font font, Single& lineHeight) at Infragistics.Win.FormattedLinkLabel.PositionElementsCache.MeasureParts(String text, Int32[] parts, Font font, Single& lineHeight) at Infragistics.Win.FormattedLinkLabel.NodeText.TextLayoutInfo.Measure(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeText.PositionSelf(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeBase.PositionHelper(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeBase.Position(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeBase.PositionChildNodes(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeBlock.PositionChildNodes(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeBase.PositionHelper(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeBase.Position(PositionElementsInfo& info) at Infragistics.Win.FormattedLinkLabel.NodeBase.CalcSize(IFormattedLinkLabelOwner owner, Graphics graphics, Int32 maxWidth) at Infragistics.Win.FormattedLinkLabel.ParsedFormattedTextValue.CalcSize(Graphics graphics, Font baseFont, AppearanceData& defaultAppearance, Int32 widthConstraint, DefaultableBoolean wrapText, GdiDrawStringFlags gdiDrawStringFlags) at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonMetrics.CalculateCaptionAreaHeight() at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonMetrics.get_CaptionAreaHeight() at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonMetrics.get_RibbonHeight() at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.RefreshDockAreaSize(Size& currentSize) at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.RefreshDockAreaSize() at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.DirtyChildElements() at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.DirtyChildElements(Boolean delegateToMdiParent) at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.DirtyChildElements() at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.DirtyAllElements() at Infragistics.Win.UltraWinToolbars.UltraToolbarsManagerRole.OnStyleChanged() at Infragistics.Win.AppStyling.ComponentRole.ClearCache(Boolean notifyOwner) at Infragistics.Win.AppStyling.ComponentRole.OnAppStyleChanged(Object sender, StyleChangedEventArgs e) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Delegate.DynamicInvokeImpl(Object[] args) at Infragistics.Win.WeakReferenceMulticastDelegate`1.WeakReferenceProxyEventHandler.OnEventFired(Object sender, EventArgsType e, Type delegateType) at Infragistics.Win.WeakReferenceMulticastDelegate`1.Invoke(Object sender, EventArgsType e) at Infragistics.Win.AppStyling.StyleManager.NotifyThemeChanged() at Infragistics.Win.XPThemes.OnThemeChangeMessage(Object sender, EventArgs e) at Infragistics.Win.XPThemes.ThemeManagerForm.OnThemeChanged(EventArgs e) at Infragistics.Win.XPThemes.ThemeManagerForm.OnNotifyMessage(Message m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.PeekMessage(MSG& msg, HandleRef hwnd, Int32 msgMin, Int32 msgMax, Int32 remove) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm)
Hello Jeffkov,
Thank you for the provided feedback.
If you have any other Infragistics related questions in the future please feel free to contact us.
It has never happened again since then and I have been keeping up to date with the newest controls (11.2), so it looks like it is resolved.
Thanks for following up.
I have been looking into your post and it seems to me that what you are experiencing here, was an issue that has been fixed some time ago.
What you could do to verify this behavior is downloading the latest service release for your Infragistics version and test your application against it.
If the issue still persisting after applying the service release, could you please let me know what exactly Infragistics version you are using in your application and under what circumstances you are observing this incorrect behavior?
If you have any other questions please feel free to contact us.
