705
Using IBindingList as DataSource to bind UltraWinGrid and show only desired columns
 Hi
 I am using IBindingList as DataSource to bind UltraWinGrid.
So as i set the binding source the UltraWinGrid is filled with object which i had send via datasource.There are as many columns as many properties i had in my object.
My problem is that i want to customize the columns as i want only desired columns not all properties which are there in my object.
Is there any option or any other way by which i could handle the columns which are shown ,except setting Hidden/Visible property ?
I need not all columns to be binded via UltraWinGrid
