I created a column chart to show Country wise city wise sales. (See attached file). Chart was showing all cities in each country. Data i provided is
Sum(Freight) ShipCountry ShipCity --------------------- --------------- --------------- 598.5800 Argentina Buenos Aires6205.3900 Austria Graz1186.1100 Austria Salzburg458.9100 Belgium Bruxelles821.2300 Belgium Charleroi
Chart was repeating All cities for each country with null values. Only labels was visible. I removed lable with the help of following code: -
class LabelRenderer : IRenderLabel{public string ToString(Hashtable context){double dataValue = 0;dataValue = (double)context["DATA_VALUE"];
if (dataValue == 0)return "";return (string)context["ITEM_LABEL"];}}
Now a large area looks blank. It shows huge gap between bars. My question is how to remove this blank area.
Nazir
sorry, this post ended up in my junk mail folder for some reason and i missed it during my regular sweep of the forums.
i'm also sorry to inform you that the column chart doesn't support uneven sets, so reclaiming that space won't be possible without manipulating the primitives directly in a custom layer or the FillSceneGraph event.
you can submit a feature request here: http://devcenter.infragistics.com/protected/requestfeature.aspx
